Weight loss program for reciprocating parts.![]()
Easy to check the CCR now , bonus.
😞...let us learn from 😉 ...what was the reason in your case?
Remember that picture...in our case four mistakes
Dyno load was kept to high, for to long time.
Ignition at peak to early
Powerjet to lean
Thanks! 😉
Wolfgang ✋️
You are onto it as usual Frits , when I first tried the semi flat top piston design in a TM the 4* conical stock piston had an 6mm dome with 3 x 2mm ribs = 15%.
I machined 1.2mm off it to achieve the 38mm Diameter 50% area flat.
That worked on the dyno to test the viability and Hp potential of the head designs, but at the track the dome sunk 1.5mm in the middle the instant it went over 620*C
with 5 full power gear changes ( our normal best power egt at the time ).
Once the com had been automatically reduced it was fine , but now of course - slower.
I ve forgotten to list our fifth reason for melting the piston.
We converted a yamaha wr 125 enduro to a yz125 cross konfiguration but kept the spring of powervalve of enduro that opend valve later...that leeds to higher compression in high revs
All in all small misstakes
All points fixed now and bike is running like never before 😉😘
Grüße Wolfgang
That's what got me thinking back in the day. In the 1980s the piston crowns of Jan Thiels unbeatable Garelli twins (six straight world titles) adjusted themselves just like you described. But I think it made the bikes faster rather than slower. In any case it made them overrev easier and every rider likes that.
To be pedantic: it leads to a higher effective compression ratio but not necessarily to a higher compression pressure because the pipe will have a word or two to say about that, and with the power valve lowering the exhaust port, the pipe will receive less exhaust gas energy to work with.
The late opening of the powervalve may well be a major problem cause, but for a different reason: it reduces the blowdown angle.area, so at high revs hot combustion gases will enter the transfer ducts and drastically raise the cylinder temperature. And when the cylinder gets hotter, so will the piston.
Right again Frits , in the two projects I have done recently , both using PV that close all 3 ports , it was a real balancing act to adjust the ignition and the PV height to prevent detonation
in the mid range. In the sim you can see the huge trapped pressure in the cylinder created if the PV is too low.
This may in fact make more power at that point, but with the TubMax ( temp of the trapped unburnt squish gases ) thru the roof , destructive deto is inevitable, and difficult to control.
The KZ overeved better as well , but though it gained about 400rpm in the top it lost more than a useable 1000 rpm on the bottom off slow corners.
Dear Frits, dear Wob,
Think diffrence opening of powervalve was only about 1000 reves...yes effektive pressure counts there... but i think that was not MAIN reason for failure
All togther was reason
AND
We tuned ignition peak by riding on the fields...rider had only chainsaw reve measurement , his eyes and feeling at his ass 😉...before we went to dyno ..and he felt peak only about 900 to late... this was the reason we set at powerpeak 3 degree to early ignition... thats realy a lot to early at this point especially if you have good filling there😮
Grüße Wolfgang![]()
[QUOTE=wobbly;1131227467]Right again Frits , in the two projects I have done recently , both using PV that close all 3 ports , it was a real balancing act to adjust the ignition and the PV height to prevent detonation
@Wob: thank's agin for that feedback, when I played around exactly that happened and after all the leassons learned from you, I went the right pass to cure that...![]()
I see that Alex Degnes ("2-stroke Stuffing") bike "Moped Dick" was the second fastest 50 at Bonneville, at 133kph (81.978mph)
There are currently 416 users browsing this thread. (1 members and 415 guests)
